Old 04-11-2010   #181
Re: 4g63tcrazy's new setup for 2010
Dang, I should have looked at those when I was at their place!
Old 04-11-2010   #182
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
^^ I need rims more then you do!
I need to find out what size tire to run/ if I need a spacer. I wont have a problem in the rear like AWD guys do. But I still have to clear the front struts. I have a little more than 1/4" of space between the back of the rim and strut right now. A 10mm spacer might be needed if I want some meaty tires.
-1990 Mitsubishi Cyborg 4WD-
Old 04-11-2010   #183
I NEED RIMS MORE! I have crappy 2gB GSX wheels Boo hiss. But I'm cheap and the roads here suck so maybe I shouldn't get a nicer set?
I was looking at my engine bay, and because of you I really want to take it all apart and re-do everything... hahaha. Your harness is awesome. I like that your changed where it enters the engine bay. So you gonna be at the Dyno Days?
Old 04-11-2010   #184
Nice pickup, I like them from a performance standby, but I haven't quite seen them look good on a DSM.
haha kevin new sig. U must of been that guy cruising 65 in the lambo back in the day.
Old 04-11-2010   #185
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Your wheels look really good on your car. Not to mention you have some sticky tires on them. Since your car is down right now it would be a good time for you to clean it up a little more! I'm kinda glad this happened cause now I have all this time to do the things that have always kinda bothered me. Not to mention I was 12k miles overdue for a timing belt!!
And yes I'll be at the dyno day at MAP. Probably the one at DB too.
I'll try and make them look good.
LOL at his sig. I saw that yesterday.
Old 04-12-2010   #186
santa
Boost Spike
santa's Avatar
I've had fd wheels on my car for 4 years now. tire size is 225 50 16 and they barrly clear the rear strut. You also have to notch the rear forward angled lower control arm even with spacers on them or else the wheels will rub. I made 530awhp last year and hooked up pretty good with 225's.
Old 04-12-2010   #187
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
FWD
I'm curious about your clearance in the front though. How much room do you have between the tire and strut?
Right now I'm either going with 235/55r16 or I might go all out with spacers, extended studs and some really fat tires. Not sure!
Old 04-12-2010   #188
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Great news! Somehow I got best of both worlds! FAT tire and no need for spacers. I ended up putting on 245/50r16's. I only have 2 on right now cause my work didn't have the others in stock. Those will get put on tomorrow. I think these wheels look SICK. I'm really excited to get the car down on all 4 and see how it looks! On to the pics!
(don't mind the thick layer of dust on the car )
LOOK AT THAT CLEARANCE!!
Less then a mm and it does not rub. I will be taking the hammer to the perch though to give me added comfort.
9" of tire-assfault traction goodness!
Old 04-12-2010   #189
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
typical women..on the phone.
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 04-12-2010   #190
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
I know right? And she thinks my new wheel setup is ugly..
Old 04-12-2010   #191
Swifty1638
Swifty1638's Avatar
eeeh..I don't think they are the best looking wheels out there, but they do serve their purpose. Tell her if they are ugly, then she can buy you some nice 16x8-8.5" wide Kosei's, Volks, Works, etc. I am sure she'd shut it then.
Black 1GB Mafia #1
I wanna go fast.
Old 04-12-2010   #192
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Haha or some RPF1's
Old 04-13-2010   #193
That's actually only about 8" of contact patch Nice setup, but I've never really cared for the way FD wheels look.
Old 04-13-2010   #194
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Close enough to 9 for me! Ha
Old 04-13-2010   #195
I think they will look pretty good
Old 04-13-2010   #196
Are those Falken Ziex ZE-912's ?
Old 04-13-2010   #197
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Yes they are.
Old 04-13-2010   #198
Yes they are.
I hope you get traction with those. I had them on my car when I was FWD for a while and they sucked bad. No traction till at least 3rd gear.
Old 04-13-2010   #199
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Thats pretty normal for a fwd dsm... lol
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 04-13-2010   #200
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Haha very true! Well I work at Tires Plus and these tires have the softest sidewalls for a performance tire. (That we carry.) All the others are stiff for cornering. They have a AA traction rating too. Either way I'll get more traction then I had before with low profile tires and 18" rims.
Update time.. Since I had the day off I installed the other 2 tires. Then I took them home and prepped the rims for paint. Ideally I would have painted the rims with the tires off but I can't have my car on jackstands taking up space. I ended up doing 3 coats of semi-gloss black and 2 coats of clear. They turned out pretty nice. While I was waiting for the paint to dry, I installed my fuse box and wired up my fans. I wired my fans up like stock for now. If that doesn't do the trick I'll add a switch later. I also took a hammer to the spring perch. Now I have 1/4" of clearance.
Here are a couple pics I took before I painted the rims.
