Old 02-22-2010   #921
Re: the evo 3 swap parts are coming
Looking good, I'm def not excited to see your car come apart again but this will be a pretty insane build once complete!
Old 03-03-2010   #922
just for you scheides
2.4 cam gears
also just picked this up from shane today
Old 03-03-2010   #923
Nice cam gears!! Are you gonna have your 255 feed that Bosch 044 then or what? Thats what it is right?
Old 03-03-2010   #924
that is what I will be doing is using the 255 to feed the 44. just need to pick up 2 push lock fittings and get it put in. then save up some more cash and off to Shane for a tune as it sits now
Old 03-03-2010   #925
Awesome
Old 07-15-2010   #926
worked on the car for the first time in a long time since it died on the way home from DB back in april. started this morring at 1030 and stopped for the day at 1245
the new temp long block till I can finish up the 2.4 and build the evo 3 head
just have to put most of my stuff on it. b.s. elem kit,ofh,hks 272s,hks twin disk,ect and put it back in next week.
Old 09-22-2010   #927
as the car sits right now
and the new not so good mod. cam fell out of the parts box
Old 09-22-2010   #928
What happened to the windshield?
Old 09-22-2010   #929
Old 09-23-2010   #930
im blind
Old 09-23-2010   #931
You should powder coat those wiper arms, too.
Old 11-10-2010   #932
nothing has really haped to the car in a long time it has just been sitting. I have no money to finnish up the 2.4 for it. So I have been thinking of selling off almost all of my car's lately not sure if I will for sure or not yet.
but what would go if I start selling things off
the evo
the spyder
the hatch
the 2g gsx auto (what I am getting for the 93 mirage) this will be sold for sure
Old 01-01-2011   #933
derick
derick's Avatar
Drives: Lancer
Send a message via Yahoo to derick
Originally Posted by Andrew7dg View Post
Hmm... I thought the Evo 3 doors were the lighter ones
Those are evo 2 doors....
Evo 1-3 doors are much heavier compared with stock, Because side impact beam was installed on the inside of each door.
derick is offline   Reply With Quote
Old 01-05-2011   #934
Constant_Project21
Constant_Project21's Avatar
Drives: E36
the evo
the spyder
the hatch
Uh wat...?
Old 01-05-2011   #935
I would guess that the evo is worth the most money, then he could finish his other projects.
Old 04-21-2011   #936
it has been a long time since I have done anything to the car since the engine died last april.
got the extra evo engine bay harness out of the bin today. Since I have not really done much to the car in a while I am starting to redo all the wiring in the engine bay and the engine harness. The fuse box will be in the car by the glove box. once it is all in I will extend the wires that will need to be extended out. also so much better than the harness in the car that has a ton more wiring with the abs.
here is the start of it. all marked to what they are for
after a few hours now just to take the car apart then get some new loom when I get it in and all hidden
what was all taken out of the harness
Old 04-21-2011   #937
took out the broken windshield
the new exhaust system that I will make fit the car. it is from my Kevins old 240sx. HKS 3.5in cat back
Old 04-21-2011   #938
got a few replacement parts for the car from the UK.
glove box. mine had something mounted to the out side of it at one time
replacement mirror switch. mine the folding switch does now work all the time
also got a ce9a data plate for the fire wall. I have a cd9a on the car right now
Old 04-21-2011   #939
engine parts showed up today
so far I have 210.10 into a set of ross pistons
pistons were free from a buddy
bought pins,locks,rings
pins that the guy from JE said were there HD ones
set of rings
new locks
Old 04-21-2011   #940
got this at the junk yard yesterday. just have to paint it since it is tan and put it in the car after I start to put it back together here
