Old 02-08-2010   #181
Re: 91 Galant VR4
I like the square stuff, but some noob questions for you.
The square stuff is for support to the body pieces and mounting right? And where it mounts to the (round tubing) frame is where the strength is?
Looks good man.
Old 02-08-2010   #182
Re: 91 Galant VR4
Yes this is a frame to hold the fenders, hood, front bumper cover, grill, and lights onto the chassis. The chrome moly round tube is the main frame that the suspension, engine, tranny, water to air heat exchanger, and radiator will be mounted. I wanted the square stock to use the flat surfaces to make it easier to mount things and the joints are easier to lay out, just cut and weld no notching needed. I decided to re-do the lower mounts for strength, I did not think the small thin gauge tube would hold up at 160+mph. I bought about 20lbs of aluminum to make all this, and it looks like I will use about 15lbs or so.
Old 02-08-2010   #183
Re: 91 Galant VR4
Cool, that all makes perfect sense to me.
I can't wait to see this thing roll.
Old 02-10-2010   #184
Re: 91 Galant VR4
Here it is, removable fender/frame assembly.
This is the first stage of removal and about half way threw the install of the front clip. I will modify the fire wall mounts so that with a second set of hands the front clip can be removed with or with out the hood on and the front wheels on and the car with it on the ground by only removing 4 pins. All this to make it easier to work on of course.
Here it is pushed in to the correct depth.
Here are the front slip connections, these are fabricated out of 1/8" mild steel and will be fully welded to the frame when completed.
The other side bracket
I think the brackets are strong, yes this is me standing on the front core support.
Never mind, I think I might have made this structure a little to strong, this is a floor jack with a 0-600 PSI gauge on top, and it only takes about 520lbs to lift the entire front end of the car right now, so I do not need to worry much about this setup flying off the front of the car anytime soon. I thought I would just see how much pressure it could handle before it started to bend or something. Now I just need to make the front bumper cover mounts, front grill mounts, head lights/turn signal mounts, then finish weld and start to paint stuff.
Old 02-10-2010   #185
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Re: 91 Galant VR4
Wow, looking amazing! Nice work
Old 02-10-2010   #186
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
Re: 91 Galant VR4
I like! When's the motor going back in? You have the rest of the cage to finish too? Is the hood, bumper and fenders all going to be 1 piece?
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 02-10-2010   #187
Re: 91 Galant VR4
Put hinges on the front, to go a little old school and raise your pimp status!!
That shit is crazy strong, good work.
Old 02-10-2010   #188
LingLing
AznKraut
LingLing's Avatar
Re: 91 Galant VR4
That's some amazing fabrication! I love the fact that you can remove your entire front end in one piece lol
Old 02-10-2010   #189
Re: 91 Galant VR4
I could multi quote but this is easier. Yes the bumper, fenders, grill and head lights will be 1 piece, then the hood will be held on by 4 hood pins, which could be left on for front end removal or pulled for spark plug changes and what not.
The cage is all done, minus the pass side door bar.
Old 02-10-2010   #190
Re: 91 Galant VR4
Haha John, proving that what you build is strong enough. Very nice.
Old 02-12-2010   #191
Re: 91 Galant VR4
The reason I was showing that is there are no rules or regulations for the front of the car. All of the NHRA and IHRA rules are made to save the driver, so figuring out how to make a tubular front end and a removable front clip is a little of a stab in the dark for me. I am lacking the needed engineering degree to know what will work so I am over building the front end. I have looked at few door slammer cars and a full tube chassis car build to come up with my cars front end design.
I did get the front bumper cover mounted up tonight, here are a few pics.
Old 02-12-2010   #192
Re: 91 Galant VR4
Very nice. What are you going to do about filling the headlight areas?
Old 02-12-2010   #193
Re: 91 Galant VR4
Did you ever dyno the engine?
Old 02-12-2010   #194
Re: 91 Galant VR4
No engine dyno yet, it has been tied up with other projects for the last 2 months.
Old 02-12-2010   #195
Re: 91 Galant VR4
Hey, that looks like a galant!
Nice work man.
U still gonna engine dyno before it goes in?
Old 02-12-2010   #196
Re: 91 Galant VR4
I still plan torun the engine on the engine dyno, but I will not loose sleep over it if I have to chassis dyno the thing.
As for the holes I plan on putting in some driving lights mounted with sheet metal. Depending on what I get there may be 2 per side. I also plan on putting in the corner lights again and I want to have working turn signals. Then I will run all the wires for the front end threw 1 connector that will be easy to disconnect for front end removal.
Old 02-12-2010   #197
Re: 91 Galant VR4
looking really good
If you still need to use the tial 38's just let me know
Old 02-18-2010   #198
Re: 91 Galant VR4
With the front clip done until I get a hood I moved the car forward and started to cut up the rear end of the car. So far I have found about 80lbs to remove. The rear doors are gutted minus the crash bar and the door handles to open it. The glass is held up by a bracket that is bolted to the crash bar. The trunk area is cut up and I bought some thin aluminum sheet to rivet in to cover the new holes. I will remount the fuel cell and make the trunk lid as light as possible and will be held on with 4 pins vs the latch and hinge setup. Then after the rear bumper is re mounted I will weigh the rolling chassis in its more complete state to see how heavy it is.
Old 02-18-2010   #199
Re: 91 Galant VR4
Nice, that schneidermans place scale sucks, but as I type this I realize that you still might have the corner scales.
Old 02-18-2010   #200
Re: 91 Galant VR4
Nice work John. I especially love tig'd aluminum, delicious.
