Old 01-26-2009   #81
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Re: Project AutoX domination!
Looking good! looking forward to seeing them all mounted up this summer
Old 01-26-2009   #82
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Unless your autoXing you probably won't see them. Unless I drive to OC with them once. These are for my R compound tires, they won't see much street time.
Old 01-27-2009   #83
You need to go full baller on this one and drive them on the street.
Old 01-27-2009   #84
^word.
Old 01-27-2009   #85
His street tires have enough grip for daily driving I am sure. Plasma cutter might be in order. Do they stick out more then Jessie's rim/tire combo?
Old 01-27-2009   #86
MustGoFaster
Yeah, they stick out more than Jessie's by a lot, he only had 9" wide rims on his car.
Old 02-03-2009   #87
Shotgun!
Totenritt
Shotgun!'s Avatar
What are their specs?
Old 02-03-2009   #88
MustGoFaster
17x10 and only 17lbs. 18mm offset.
Old 02-04-2009   #89
Shotgun!
Totenritt
Shotgun!'s Avatar
Dang, thats a crazy low offset!
Old 02-04-2009   #90
MustGoFaster
About the highest I could go would be ~25mm, that would get me ~3mm clearnace to the strut. But with the lower offset I can run wider tires later if I chose to.
Old 03-04-2009   #91
MustGoFaster
Since I'm planning on more TQ and more traction I decided to add a little more strength to my drive train. This is called a Transfercase brace, and it eliminates the 1st weak spot in my drive train. The transfercase housings like to crack when launching with a lot of power and grip. The braces are proved to be quite effective, a number of people have run 10 second 1/4 mile times for a few years with out cracking the case with a brace.
It goes on this thing in case your wondering:
Old 03-04-2009   #92
Sick.
10" wide. =
Old 03-19-2009   #93
MustGoFaster
10" wide SLICKS =
Update: I hooked up my oil temp and pressure gauges. The coolant temp is wired, but I need to install the sensor. The boost gauge will be down under the radio.
Old 03-19-2009   #94
Gauges, those are only used for tuning of is something goes wrong. I do not think I looked at any of my 5 gauges in my car when I was driving it. But that is a really nice Tcase brace, so nice I do not see the need to make a better one, that does not happen often, enough.
Old 03-20-2009   #95
Very nice brace Ryan.
Old 03-20-2009   #96
Constant_Project21
Constant_Project21's Avatar
Drives: E36
I knew I shouldn't have read through this thread..haha. I get the itch to get a 3/s sooo bad. I should just man up, fix the talon, and buy one this summer.
Old 03-20-2009   #97
MustGoFaster
The blue thing in Niterydr's avatar is what tainted me.
Old 03-20-2009   #98
The blue thing in his avatar got my taint all over it when no one was looking.
Old 03-21-2009   #99
Old 03-21-2009   #100
rofl!
