Old 11-19-2008   #1
iceminion
iceminion's Avatar
My GVR4's engine...
Well, I finally took my 2.3 out of my car, looks like my rod is screwed, where is a good place to get my rod re-sized?
Look the the THRUST BEARING?!?!?! it has worn all the way through!!!
as far as I can tell, the only damage was to the thrust bearing and to rod #3
I don't know what caused the failure....anyone know how to track down what happened? Had 5 qts in there, no leaks (so beautiful, a dry engine)
stock timing tables (yeah, i know) , 10 lbs of boost...one good launch..SC61 chipped for the 780's
i basically blame this on the lack of tuning/not running synthetic oil
Thoughts?
building a 3000GT AWD Turbo.
Old 11-19-2008   #2
Re: My GVR4's engine...
I am pretty sure if the thrust bearing goes out, every bearing will be bad. (maybe not mains, but definately rod bearings).
Old 11-19-2008   #3
That would be crank walk. Do you have ARP main studs? Normally this is from misaligned mains. Maybe it was crap in your oil
Old 11-19-2008   #4
iceminion
iceminion's Avatar
LOL, you got me good JET.
no this was virgin clean oil.
Stock mains/bolts....thats really strange
Old 11-19-2008   #5
IT was virgin clean oil, till you started the car.
I wouldn't blame conventional oil, its fine.
Old 11-19-2008   #6
iceminion
iceminion's Avatar
I think jet was asking how many keepers were in the oil pan
Old 11-19-2008   #7
Assembly error? Did you set/walk the bearing?
Old 11-19-2008   #8
OmgAwd
OmgAwd's Avatar
Drives: 1992 Eagle Talon TSi Awd
Did you buy oversized/undersized bearings where it needed otherwise?
OmgAwd is offline   Reply With Quote
Old 11-19-2008   #9
Assembly error
Improper tolerances (plastigage?)
Dirt
Didnt set the thrust bearing correctly
Old 11-19-2008   #10
jhaan_dude
jhaan_dude's Avatar
Drives: a car
He Has A Turned Crank!!!
Old 11-19-2008   #11
iceminion
iceminion's Avatar
I bought this engine quite a while ago for $2000(before I knew how to build engines), if i were to do this again, I would build it myself, so far every engine build I have done has been successful.
Yes, it has a turned crank, I did not know this until I bought this. I do feel kinda ripped off.
I will be asking the builder of this engine some more specific questions, and maybe we can come to an agreement.
I will not divulge his name to protect his reputation.
Old 11-19-2008   #12
Turned cranks seem to show up as more of a problem then they are worth. The 97+ 7bolts and 6g7x series thrust washer design seems to hold up a lot better, to bad our 6bolts can't use them.
