Old 09-26-2008   #1
just got a new winter car 95 mirage coupe
1995 rage 1.8 auto coupe.
the engine needs to be replaced or rebuilt it has rod knock.
needs some body work on the right side some one had macco do it and it is cracked from to much body filler.
needs a new windshield
got it for 150.00
will fix it all up and do some mods to it and give it a quick paint job. I will drive it this winter and sell it in the spring
some things I am thinking of doing
5 lug
2 piston fronts
rear disk set up
evo III master
rebuild or replace engine
5 speed swap (if I can find one in the junkyard)
new front bumper
paint/body work cheap
tint the tails
dsm 16in rims oem
maybe a turbo kit
Old 09-26-2008   #2
Re: just got a new winter car 95 mirage coupe
body damage drivers side
rest of the body
need new front bumper it has a hole in it and was pushed in
14in oem rims
inside need seats
engine 1.8 auto
Old 09-26-2008   #3
4G63T swap or ban.
Old 09-26-2008   #4
I dont have a engine to put in to it other wise I would
Old 09-26-2008   #5
twack
twack's Avatar
4G63T swap or ban.
come on make another evo.......that will actually get painted
Old 09-26-2008   #6
I got a FWD transmission you could bolt in there....
Old 09-26-2008   #7
I will paint the other car when I am done working on it not before. But I will be using the same paint on this car to see how it works before I spent the time and money on the evo.
the tranny would have to be a 2g tranny
Old 09-26-2008   #8
311evo
311evo's Avatar
i have a crankwalked 7-bolt if you want it :P
Old 09-27-2008   #9
Sweet! You could just mod it to get ridiculous gas milage!
My front seats in my 1G should be coming out here sooner or later. I'd let you have em fairly cheap if they happen to bolt in there.
Old 09-27-2008   #10
they do with some modding
Old 09-27-2008   #11
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
I have a cable 4sp trans
Old 09-27-2008   #12
twack
twack's Avatar
this is a panty dropper if i ever saw one
Old 10-02-2008   #13
well I said I was just going to fix it,but I was at u pull it today and got this instead of the 1.8 replacement
here is the engine. It came out of a 94 gsx so it is a 1g 7bolt. was a reman engine and head from B&M. the engine also had a act 2100 on it big +
all the extra parts
the awd tranny that is locked to fwd that I had taken apart and fixed before and it is now back to me after 3 people
Old 10-02-2008   #14
Hahaha I had a feeling that would happen.
Old 10-02-2008   #15
ya I was trying not to but that is what always end up doing in the end
but I will not make it awd unless the buyer of it want it done when I sell it
it is just going to take custom mounts
wire in craigs old 90 harness in the car and get a 90 ecu for it
Old 10-02-2008   #16
I wanna drive this thing when it's done
Old 10-02-2008   #17
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
You know that engine would look alot better on an engine stand.
Old 10-03-2008   #18
ya get it back to chris's house so I can use it
Old 10-03-2008   #19
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
nice... look forward to seeing the progress on this!
Old 10-03-2008   #20
well today I sold the evo III rear brake set up and the 1.8 injectors so dad and I went back to u pull it and a 2nd junk yard and got more parts for the swap
first stop they had a 1.5 5 speed so I got the shifter and cables and a 1g bov for 15.00
then off to u pull it got parts off the same 94 talon
front hubs,2 pistion brakes,rotors,axels that need to be fixed or use them as cores, also got a 90 n/t t.b.
also going to use my evo 8 booster,master,clutch master on the car
