Old 06-26-2007   #1
driftn1g
removing the awd system from tranny
ok so as i was removing the engine i remembered that the awd system is still hooked up to the tranny..
how do i safely remove the front wheel drive so i can pull it?
Old 06-26-2007   #2
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: removing the awd system from tranny
... what? Are you talking about the Transfer case??
Old 06-26-2007   #3
Shane55113
Now 20% less Racist
Shane55113's Avatar
5 bolts on the x-fer case and a dead blow to knock it off, then slip it off the drive shaft yolk and use some mechanics wire(or whatever) to hold up the drive shaft so its not on the ground.
Old 06-26-2007   #4
driftn1g
let me go get a pic lol
Old 06-26-2007   #5
driftn1g
this whole system (FWD)
Old 06-26-2007   #6
driftn1g
i guess im kind of confused on what is Xfer case and tranny... heres what i think it is.. am i right???
Old 06-26-2007   #7
Grab a pry bar, and pry the front drive axels out of the transmission, get the transfer case off (the thing bolted to the transmission under the engine) and it's good to come off. In your second pic, that whole thing is the transmission.
Old 06-26-2007   #8
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
no, transfer case is a separate unit from the tranny, it will be the unit the driveshaft is attached to, kinda to the side and behind the tranny sort of.
Old 06-26-2007   #9
driftn1g
so its under the tranny? ... where do i pry them off at?? do they just pop back in?
EDIT: Ok so is it a small unit?? im going to take a pic to make sure brb
Old 06-26-2007   #10
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Here, look at this clutch install walkthrough for reference, maybe it will help you better understand what you need to take off: http://www.vfaq.com/mods/clutch-1G.html
plz buy a manual after this, it's well worth the $20 or so.
Old 06-26-2007   #11
driftn1g
ok after reading method 1 im going to go try.. i figured i would have to remove the wheels
Old 06-26-2007   #12
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
nvm. continue with the walkthrough.
Old 06-26-2007   #13
Speedfreak
Drives: four tires
If this is a FWD, there is no transfer case.
You need to pry out the axles, and push or pull them away from the tranny. In your first pic, what you have circled are the axles. I'm assuming the link clean2g posted will tell you how to do this.
Your second pic is the tranny.
You do not have a transfer case at all(if your car is FWD, like you have posted).
Old 06-26-2007   #14
x-pride
x-pride's Avatar
Since you look confused make sure you drain both your tranny and transfer case fluids. Yes, both. Also you will need to remove your exhuast to get your transfer case off from under neath the car. Yes the transfer case got some weight to it so when you pry if off make sure you have a jack or something to support it so it does not drop onto the ground. If you are replacing the tranny with another tranny make sure you count you splines on your tranny or your transfer case is not going to slide on.
Old 06-26-2007   #15
driftn1g
i got 1 out of the two now removed... (damn bolts)
do i have to pull the transfer case?? can it just come out with everything else?
this car is AWD
Old 06-26-2007   #16
Hoffer00
Cantankerous Tank Champion! Fight Man Champion! Go Johnny Go Champion!
The Transfer case has to come off because it is attached to the rear drive axle
Old 06-26-2007   #17
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Which one did you remove?
It sounds like you are sill confused on what is the transmission and what is the transfercase. The transmission is the large hunk of metal pictured above. It's where your shifter linkage is at and both front axles come out of it (one on each side). It bolts to the engine and comes off by pulling towards the passenger side.
The transfer case is more rectangular and about 1/3 the size (just a guestimate). It is located more towards the center of the engine bay kind of behind and to the drivers side of the tranny. It is what the rear drive shaft attaches to. It bolts to the transmission itself and is removed in the opposite direction of the transmission (pull towards the drivers side).
Old 06-26-2007   #18
friggin newbs
Old 06-26-2007   #19
driftn1g
ok cool..
I have to get the transfer case off still... but im stuck on this
Pull the hub down and pull the passenger axle from the transaxle. A pry bar must be used inbetween the CV joint and the transaxle to release the retaining clip on the axle end.
Where is the clip at?? and where do i pry??
PWNED
Old 06-26-2007   #20
xveganxcowboyx
Wanker
Drives: 95 M3
You pry right where the axle meets the transmission. You should be able to wedge a crowbar or large screw driver in there and pry. I find a solid "pop" works well if you can keep it steady vs steady prying. This is of course assuming you have the hubs and axle seperated already. I can't tell by your post if you have removed the hubs yet or not. Obviously the axles will have nowhere to go if they are still attached to the hubs.
