Old 12-07-2006   #1
brown man needs one of these!
http://forums.evolutionm.net/showthread.php?t=238721
scheides is online now   Reply With Quote
Old 12-07-2006   #2
Re: brown man needs one of these!
It's cheaper to use a plyers and crimp the top just a bit.
Old 12-07-2006   #3
That is genius.
Old 12-07-2006   #4
Enes
Enes's Avatar
I have ben using a spring since last summer... wow never tought to market it tho..
Old 12-07-2006   #5
I have never had that pop up before. Why does it do that in the first place?
Old 12-07-2006   #6
Bode
Bode's Avatar
Drives: 01 Impala
Blow bye, It has never happened to me either.
Bode is offline   Reply With Quote
Old 12-07-2006   #7
Thor06
11 Seconds to Freedom
Thor06's Avatar
That is amazing, the Talon is definately getting one of those.
Old 12-07-2006   #8
Swifty1638
Unsure resident asshole
Swifty1638's Avatar
I actually have a metal bracket I made for mine. It's a thin bendable piece of sheet metal, that has a groove cut into the top of it, that slides over the handle of the dipstick. Then, it's held to the tube by a small hoseclamp.
-A. Swift
Black 1GB Mafia #1
744AWHP/526TQ-Shootout mode
639.6AWHP/452TQ-DB's dyno
I wanna go fast.
Old 12-08-2006   #9
Ha fricken ha.
I got that shit sorted, plus its cold now, so maybe i will have to unsort it?!!
nice one
Old 12-08-2006   #10
Isnt Blow by a REALLY bad thing. My buddy with a turbo integra got that and he ended up having to get the block rebuilt.
Old 12-08-2006   #11
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
That's why your supposed to put boost pressure to the crank case, to help reduce blowby.
Old 12-08-2006   #12
Onefast99gsx
Weird....i just posted in the Internals section about replacing the rings because of blow by. I'm sick of the dip stick popping out and blowing oil everywhere. I clamped my dipstick in temporarily but i hate the idea period. If you have to clamp, crimp or whatever, then you're not getting to the real source of the problem. I think of the dipstick as a pressure release valve. If it's clamped in there, then your sealing up the motor tight. That can't be good. I sure don't want the side of my block to open up and become the new pressure release valve.
Old 12-08-2006   #13
I have heard from someone on here, that blow by is a thing that all dsms have and is ok to have because that is what the pcv valve is for. or something like that.
I suppose being that ive Never had the problem of my dipstick popping out its likely a good thing. (or means i need to add more boost so that it does happen hehehe)
Oh shit Raptor is back and signed on to MustGoFaster's screenname.
Old 12-10-2006   #14
Bah, it can happen to any engine, it may not be caused by blowby, it could be a random surge through a messed up PCV with high boost.
get a crankvent setup. some checkvalves - one for vac. only from the valve cover, then one for pressure from the crankcase -> to a nipple on the exhaust, and when there are vacuum pulses in the your exhaust, it'll suck out and burn any positive pressure. easy.
