Old 10-08-2006   #1
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Crank removal Q's
I checked VFAQ , Tuners DIY, and my Manual found nothing. I have a 6 bolt motor out of car, head removed, pistons out, oil pan off, but cant figure out how to get the crankshaft out. Theres gotta be a little stupid trick.
Right now the crack wiggles but just wont come all the way out.
sorry, this should be in internal tech.
Old 10-08-2006   #2
Snafubmx234
Re: Crank removal Q's
I'm assuming you've disconnected the transmission, mains and all that stuff?
On my B18B1 I had to take the end of a wooden mallet and tap it out. Engine oil can create a type of suction to bearing surfaces.
Snafubmx234 is offline   Reply With Quote
Old 10-08-2006   #3
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Yeah, its just the block all the belts and water pump have even been removed. I smashed the end on the timing belt side with a weighted rubber mallet. Also I took the 6 bolt peice off the opposite side it had 5 10mm bolts.
Old 10-08-2006   #4
blageo23
AWD4G64
blageo23's Avatar
You need to either remove the front cover or the rear main seal(or maybe both I cant remember).
Old 10-08-2006   #5
Gravy
Who's this guy?
Do you need the eninge out and tranny off to remove a crank from a vehicle?
Old 10-08-2006   #6
acidrumz
remove the front oil case, the oil pickup filter (remove that first then front case), the rear oil seal, flywheel and the main brackets. that one should have 8 bolts. pry the main brackets to remove them. notice the arrow on the brackets that points to the timing belt side of the engine for reinstallation.
goodluck.
Old 10-08-2006   #7
acidrumz
you would need to remove the tranny for clearance to remove the flywheel from the crank. and the there is the rear seal behind that flywheel too. so i suggust remove the whole engine. easier for reinstallation.
later.
Old 10-08-2006   #8
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I bought just a block from slowbubblecar, I beleive its Jet's old one. He told me that there was a hole in the piston so I went searching. Found no hole but I want to rebuild everything. Ill try what you guys have suggested thanks.
