Old 01-22-2010   #1
DSM_brother2
Drives: to the shop
relay next to the ecu on a 1g
im in the process of building my car and im trying to crank it over. i have a new starter that i know works. but when i turn the key all it does is click from that relay. ive looked online and it says its a mpi and fuel pump relay. will that affect it from starting? its on a 1g
thanks
93 talon tsi/ 6 bolt swap
Mitch
Old 01-23-2010   #2
CarPsyco84
CarPsyco84's Avatar
Re: relay next to the ecu on a 1g
Have you verified the battery is good? the connections to the battery? Do the lights dim or go out when you try to start it? Did the signal wire that switches the starter get connected? is the wire between the solenoid and the starter motor fry?
-When in doubt, Moar RPM.
Old 01-23-2010   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
That is the relay for the fuel pump. If that's just clicking or not working properly your car will not start.
-1990 Mitsubishi Cyborg 4WD-
Old 02-01-2010   #4
iceminion
iceminion's Avatar
I second checking the connections, I had identical symptoms on my first engine swap, turned key, "click" nothing.
Battery was good, everything was good...or so I thought
I had missed one of the wires going to the battery, based on that you haven't replied I assume the issue was resolved.
I would not ever call into question the little relay box next to the ECU. DSM electrics have their issues (leaky capacitors), however I have found the overall quality of mitsubishi's wiring/electronics to be exceptional.
building a 3000GT AWD Turbo.
Old 02-01-2010   #5
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Like was stated earlier, make sure all wiring and grounds are connected, and that the battery is good.
The only issue I've had with one of those relays was the cover rattling loose on the MPI relay. The case made contact with the relays inside and kept blowing the MPI fuse.
Snapped the cover back in place and JB welded it. Been good for 10K miles since
