Old 04-12-2008   #1
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
oil pan gasket
Not sure what the part number is, but I've got a 7bolt gsx and I need an oil pan gasket. Thanks
-brian
pics or gtfo
Old 04-12-2008   #2
Re: oil pan gasket
They use an expensive goo, not a gasket.
Old 04-12-2008   #3
DSM_421
Re: oil pan gasket
RTV is your friend.
Old 04-12-2008   #4
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: oil pan gasket
Factory says use RTV. I believe you can get a paper gasket if you want to buy topline...
Old 04-12-2008   #5
dedlewamp
Drives: 4G63
Re: oil pan gasket
Just use some quality RTV. Make sure the whole pan is level, and don't overtighten the bolts.
dedlewamp is offline   Reply With Quote
Old 04-12-2008   #6
HiImBrian
HiImBrian's Avatar
Re: oil pan gasket
black rtv it is! Thanks
pics or gtfo
Old 04-12-2008   #7
DSM_421
Re: oil pan gasket
Yea, do you have a torque wrench?
Old 04-12-2008   #8
xveganxcowboyx
Wanker
Drives: 95 M3
Re: oil pan gasket
It's 60 inch pounds. Similar to the valve cover bolts. Basically just passed finger tight if you're wrench less.
Old 04-13-2008   #9
HiImBrian
HiImBrian's Avatar
Re: oil pan gasket
^are you talking about the oil plug? Because I was told before that you should make sure that bolt is nice and tight.
pics or gtfo
Old 04-13-2008   #10
dedlewamp
Drives: 4G63
Re: oil pan gasket
I believe he was talking about the bolts that go around the oil pan. If you over tighten them you risk either stripping them out, or pushing all the RTV out and causing a leak.
Old 04-13-2008   #11
HiImBrian
HiImBrian's Avatar
Re: oil pan gasket
Gotcha, anybody know how tight the oil drain plug should be? I'd guess about the same???
pics or gtfo
