Old 02-18-2005   #1
Onefast99gsx
Question Is it possible to run 11.99 or better on my setup here.....
Ok, so i'm penny pinching here and having a huge debate with myself on whether I absolutely need a Magnus or like to acheive my goals. My goals are not Horsepower, they are et's at the track. I would like to acheive at least 11.99.
I have a brand new PTE 50trim, 780cc injectors, Griffin FMIC 2 1/2" piping, Dsmlink v2, Fidanza flywheel, ACT2600, 3" exhaust, 1g throttle body, stock 2g head, stock 2g intake, and all the other little mods.... Will have HKS 272's by spring. BTW- Car is a '99 GSX.
Do you mandate a need for the over-pricey Magnus to achieve my goal? I'd like to save the $700 if my goals can be acheived without it. Bottom line- Can i make the power out of my 50trim and stock 2g head/intake?
Thank you...
I soon hope to end my debate.
Old 02-18-2005   #2
Re: Is it possible to run 11.99 or better on my setup here.....
Good driver, Good Track, Good Tuning, and a Good Run...... sure.
Old 02-18-2005   #3
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
I would say consistent low 12's with that setup. Unless all the above criteria are met with a little luck.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 02-18-2005   #4
It would be close on that set-up.
I would say before spending $700 on the Magnus SMIM, spend a couple hundred on a 1g head and intake. That would get you there, if the tuning is right.
Old 02-18-2005   #5
Onefast99gsx
Thanks guys! I actually have a 1g intake but no 1g head(YET). I've been looking for one for a few days now.
I ran a best of 14.05@102. with my old '97GST(sm16g) and now i wanna jump to 11.99 with my GSX. Something is wrong with that ;-)
I'll keep looking. I hate to buy a head off ebay. Maybe i'll find one locally.
Old 02-19-2005   #6
92.5Talon
Sorry buddy, you can't publicly sell stuff yet. If you have something he might want send him a PM and ask him out of public view.
CRAIG
92.5Talon is offline   Reply With Quote
Old 02-19-2005   #7
95tsi
95tsi's Avatar
Drives: a pos
Just go to the track and see what it runs... if it isn't getting there get the SMIM. I've gone 12.6 on my T28 and I've yet to even pull off the valve cover. I would think you should be able to get around the 11.99 with a descent track and tuning. just my opinion.
Old 02-18-2005   #8
That 102 trap should net you mid to low 13s with a good lauch. Probably better than that since a 101 trap speed had me in the 13.4 range with just a T25 turbo. Put the power to the ground with a good clutch, tire setup, and good track conditions.
Old 02-18-2005   #9
Onefast99gsx
Yes, and that 102 trap was on a small 16g setup. Probably was the FWD! Wheel hopped like a bastard. The year after that 14.05, I pumped it up even more with alcohol injection, more boost and actually went slower et's because i simply wheel hopped even more. MPH stayed about the same 102ish. FWD's are simply for the highway and that's it. I'm a pretty good tuner i think. I have yet to learn all about dsmlink. I only tested it once before putting car away for winter.
I just wanna pound on my brothers back door is all. He's got a domestic car that runs 11.20's and for me to hit 11.99 would sorta make a statement.
Old 02-18-2005   #10
ewwwww
Old 02-18-2005   #11
Onefast99gsx
Originally Posted by DSMStyle
ewwwww
Yes, i guess that came out the wrong way didn't it. hehehe
Old 02-18-2005   #12
ACRucrazy
ewwwww
ROFLMAO!
I was thinking the same thing! LOL
Slow stuff
ACRucrazy is offline   Reply With Quote
Old 02-18-2005   #13
Well I know that Jeremy Brandt ran a 12.28 @ ???? with his '99 GSX a couple years back. From what I can recall his mods were stock 7 bolt, FP T28, AFC, 660s, and a ACT 2600. I'm not sure what he was running for exhaust at the time but I believe it was a 2.5" turbo -back. I also believe that run was made at Tri-State Raceway at Earlville but Allan may correct me on that one. I'd say this all gives you a pretty good chance of breaking into the 11's.
Old 02-18-2005   #14
Onefast99gsx
Thanks Jakey for your input. That's sweet hope. Even 12.0's - 12.2's i think would make me very happy. I'd rather have a low 12 second car that's reliable than a 11 second car that goes thru tranny's, etc.. left/right.
Old 02-18-2005   #15
TheBlizzard
TheBlizzard's Avatar
With that setup you should into the 11's even without the intake manifold upgrade. If you can drive and are at a decent track.
CRAIG
Old 02-18-2005   #16
Why would you use a 1g Head? If i recall the 2g head was better in a couple respects.
Old 02-18-2005   #17
Untouched the 1g head is better. If you want the most flow possible, and are willing to spend the money on max porting, the 2g is a better head.
Old 02-21-2005   #18
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
I thought the 1g - 2g heads had different passeges and such? So using a 1g intake mani on a 2g head is a stupid idea?
- Josh L.P.
Old 02-21-2005   #19
It's not the greatest idea. There will be a miss-match between the ports.
Old 02-18-2005   #20
Onefast99gsx
Yes, i believe the 2g head is better in the long run because of the port angle or how the flow aims at the valves. I think if you're gonna get a sheet metal intake, the 2g head is better but if you're gonna stick with a stock intake, then the 1g stuff is better. That's not quoted by me, i read that on dsmtuner. What they say is that most of the hardcore people are starting to use 2g heads now.
