Old 06-10-2004   #1
Tachyon
Tachyon's Avatar
Drives: Icarus
Anybody here like informal track racing? If I get my car up and running soon I am soo going to this event. http://forum.mnautox.com/read.php?TID=1467
-Sebastian Vettel
Old 06-10-2004   #2
ABV
ABV's Avatar
I went to the last event they had there on memorial weekend. That track layout is awesome. And $30 is dirt cheap for how much seat time you get. At the last full day event I had a good solid hour of seat time for $75. Definitely worth the money. If you've never been to one, it's worth the effort to go and drive your car balls to the wall without worry of tickets, hitting little kids or animals, or anything like that. You can still crash though. :naughty:
Go check it out. Hopefully I will be there if I can get a few things sorted out on my car.
Old 06-10-2004   #3
Black97civic
35mpg
What equipment do you need to pass safety inspection??
You need fire extinguisher, helmet, that sort of thing?
Old 06-10-2004   #4
ABV
ABV's Avatar
Here is the checklist for tech.
You don't need to have a fire extinguisher, but it couldn't hurt. You do need an M95/SA95 or better helmet though.
WHEELS AND TIRES
_____/_____ tire in good condition
_____/_____all lug nuts present and tight
_____/_____ no hubcaps or beauty rings
STEERING AND SUSPENSION
_____/_____ no excessive wheel bearing play,
F+R
_____/_____ no excessive steering play
MISCELLANEOUS
_____/_____ gas cap secured
_____/_____ no exposed wires
_____/_____ camera secure
_____/_____ battery covered
(inside cockpit) ENGINE
_____/_____ no fluid leaks (oil, fuel,
water)
_____/_____ radiator overflow
(condition)
_____/_____ battery secured
(no bungees)
_____/_____ battery terminals covered
_____/_____ starter solenoid covered
_____/_____ fluid lines (condition)
BRAKES
_____/______ pedal pressure ok
_____/______ fluid level ok
_____/______ lines (condition)
_____/______ brake lights working SAFETY EQUIPMENT
_____/_____ Rollcage,
(required for open cars on racing tires)
_____/_____ roll cage padding ok
_____/_____ safety harness ok
_____/_____ helmet (Snell SA-95 or
newer, M-90 or newer)
OPTIONAL SAFETY EQUIP
_____/_____ driver suit
_____/_____ driver shoes, gloves, etc.
_____/_____ fire extinguisher / system
_____/_____ fuel cell / tank / lines
_____/_____ window net / arm restraints
_____/_____ master switch ( if equipped)
_____/_____ head restraint
I have inspected the above vehicle and take full responsibility for its condition on the track.
OWNER / DRIVER SIGNATURE ___________________________________DATE___/___/___
Tech inspector’s comments (list and violations) Inspector: Please do not sign until all violations have been corrected. __________________________________________________ ___________________________
TECH INSPECTOR SIGNATURE __________________________________ DATE ___/___/___
Paid _______, Car #______, Trans, __________ DRIFT,_____ Check Ride, _______
