10-18-2003
#2
Business as usual
That sucks. I can give you a used timing belt. It has a groove running up one edge. Also, I have a snapped b-shaft belt if you want to use that also. Both belts only have 20,000 miles. Should last another 40,000. j/k
97 Viper GTS
10-18-2003
#3
ConArtist
Sorry to hear about that Peter.
As far as valves hitting the pistons, I have that cool little tool known as a boroscope that will tell you for sure without pulling the head if you are curious. All we need is to pull the plugs and go right in through there. Let me know if that interests you.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
10-18-2003
#5
ConArtist
Anytime next week is fine Peter, just let me know what works for you. And thanks, I do feel much better!
651-488-7774
10-18-2003
#6
Wouldn't a simple compression test be easier than sticking something down the intake in this case?
Originally Posted by Tachyon
10-18-2003
#7
Wouldn't it be possible for there to still be some damage but yet run good compression numbers?
10-18-2003
#8
Originally posted by Jakey+Oct 18 2003, 01:29 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Jakey @ Oct 18 2003, 01:29 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Matt D.@Oct 18 2003, 12:58 PM
Wouldn't it be possible for there to still be some damage but yet run good compression numbers? [/b][/quote]
My thought is if the pistons kissed the valves in any way they'd be bent and wouldn't allow for very good compression at all if he previously had good compression.
10-18-2003
#9
Sten Sniper
Drives: Evo VIII RS
Thats my thinking.
if the valves did hit, then it would be good for checking how bad the damage is, and seeing if you need new pistons before you start opening things up.
10-18-2003
#10
Originally posted by Matt D.+Oct 18 2003, 01:44 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Matt D. @ Oct 18 2003, 01:44 PM)</td></tr><tr><td id='QUOTE'>
My thought is if the pistons kissed the valves in any way they'd be bent and wouldn't allow for very good compression at all if he previously had good compression. [/b][/quote]
I wasn't sure if there was any sort of tolerance built in for valve damage = lower compression.
10-18-2003
#11
ConArtist
it is worth it to do both, but seriously you already have the plugs out to do a compression test, wouldn't it be nice to actually look at the pistons rings and cylinder walls if you have that capability? Visual inspection is nice and is an easy way to figure out for sure if there was piston to valve interference. Not to mention if you pay attention while you are in there other things could be spotted as well such as damage to the piston top from detonation etc.
651-488-7774
10-18-2003
#12
Business as usual
You plan on doing all of these tests after the new belt is on right? Dont want it to skip anymore. Doens the car not even crank when you try to turn it over?
97 Viper GTS
10-19-2003
#13
ConArtist
The boroscope can be done before the belt. The engine doesn't need to be turned over for that, it is just visual inspection. If that shows there is no significant damage or indication of valve to piston impact, redo the timing belt then do the compression test to verify things are in order. If however there is valve to piston impact, it will show up with the boroscope test and I would pull the head at that point and check the valves to make sure they are seating properly and not bent.
651-488-7774
10-19-2003
#15
ConArtist
Tuesday or Wed either one. 952-292-7254 give me a call if you want and we can figure out when for sure. Keep your dad away from it for a few days
651-488-7774
10-27-2003
#17
Well last wednesday Mike-Raptor came over with the boroscope and we determined that valves did slightly touch the pistons. So on Friday I put it back together, just the T-belt and balance belt and we checked compression with nothing else put together. Compression in all 4 cylinders was 150. If any of them were under 140-145 I would rebuild the head....
But since compression was good, on saturday I put the rest back together and started it up. It started and I drove it and it vibrated like MAD... couldnt go over 3k because it felt as if it would fall apart...
So had to pull everything apart again on Sunday and everything looked lined up, well I skipped the step that determines if the right balance shaft was lined up right (it is behind the Oil pump assembly and is run by the gear...
So anyway put it all back together again and had success, car ran smooth as ever and it seems to be good to go. Got lucky with the Valves.
Thanks for help again Mike.
If anyone needs help with a Tbelt I think ive become certified this past weekend.
10-27-2003
#18
Good to hear, Peter. Hopefully you'll gain some more power out of this.
10-27-2003
#19
Business as usual
Nice to hear it is running fine.
97 Viper GTS
| Thread Tools |
| Display Modes |
Hybrid Mode
