Old 01-09-2008   #1
Need some plastic clips
For my 88 quest (starion). I don't have part numbers for these ones, so sorry in advance!
I need 6 or 10 or whatever you can get in that range, if they are cheap, maybe 12 of the white ones, and the same amount of the black ones if possible.
The white ones are the snap-on clips for the front plastic grille above the front bumper.
The black ones hold on the back carpeted panel in the trunk that goes accross the tail lights, The one in the picture is the only one I have left and it's a bit broken, but both of the "legs" that form the triangle shape should be connected at the top and bottom. the big end of these are square.
Here are some pictures to help identify them: (that's a quarter in the 1st pic)
Thanks!
Andrew
Old 01-09-2008   #2
dedlewamp
Drives: 4G63
Re: Need some plastic clips
You should be able to go to any Napa or O'Reilies and find something that will work. Of all the times I've needed a clip like that, the local stores have always had something that either matched exactly, or was close enough that it worked just fine.
dedlewamp is offline   Reply With Quote
Old 01-10-2008   #3
Nick G
Nick G's Avatar
Snow Storm Champion!
Drives: 94 v10 Ram
Im not able to find any numbers in the microfiche
you could try chrysler or aftermarket
thank you!!
Nick
LUTHER BROOKDALE MAZDA MITSUBISHI
763-503-4695
nick.galbreath@lutherauto.com
http://www.facebook.com/#!/Luther.Auto.Dealerships
http://www.Lutherauto.com
Nick G is offline   Reply With Quote
Old 01-10-2008   #4
well, I checked the napa and carquest here in Moorhead and they couldn't help me. My other option is to find a junkyard car and gank the clips from there, but Mitsu actually has new parts for quests, so I may as well go resto-mod style and get 'em from the OEM.
Old 01-10-2008   #5
Nick G
Nick G's Avatar
Drives: 94 v10 Ram
I went through the parts on my shelf and I cant find anything close
sorry
thanks
Nick
763-503-4695
