Old 04-21-2009   #1
v8klla
v8klla's Avatar
New Competition Clutch Twin Disc Clutch Kit for Evo 8 & 9
Competition Clutch's new twin disc for the Evo platform has finally arrived. It is the perfect choice for enthusiasts searching for a cost effective twin disc clutch kit that will hold upwards of 700whp! Utilizing the ideal flywheel weight and a linkage type pull to push conversion also provides improved driveability over the competition!
Specifications:
Power Capacity: est. 700 ft/lbs
Flywheel Weight: 14.5lbs
Disc Material: .250" Cerametallic / Solid Hub
Disc Splines: Heat Treated / HRC 40
Pull to Push Conversion: Linkage Type
Applications:
All Evolution 5 Speed and 6 Speed Platforms
Click here for more information or to get yours on the way today!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 04-21-2009   #2
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: New Competition Clutch Twin Disc Clutch Kit for Evo 8 & 9
Do their hubs wear or eat your shaft too like the PTT and Tilton? Has anyone tested one for more than 5k miles? J/W.
'04 Honda Ricer: stock
Old 04-21-2009   #3
v8klla
v8klla's Avatar
These are still fairly new so there aren't many on the road, but at least two have been tested on DD applications with great results thusfar. If you notice the specs above the splines are heat treated to a Rockwell Hardness of 40 to avoid exactly what you explained above.
P: 763-545-3800
