Old 06-18-2009   #1
v8klla
v8klla's Avatar
Wossner Pistons Now Available @ MAPerformance! Introductory Sale Inside!
We stumbled across these bad boys at Sema and finally got around to becoming a US distributor! Check out the specs, images and our initial impressions below.
If you would like more information or introductory sale pricing please contact us!
We are looking to generate several customer reviews, so we will do what we can to get Wossner pistons in your engine!
Available Applications: 6 Bolt DSM / 7 Bolt DSM & Evo (2.0L and 2.4L Variations)
Available Bore Sizes: 85mm / 85.5mm / 86mm / 86.5mm / 87mm
Compression Ratio: 8.0:1
Included Components: Pistons, Rings, Wristpins, Locks
MAP Initial Impressions
When we first saw these at their Sema booth in Las Vegas it was clear that Wossner pistons aren't your average piston. The amount and placement of material in the design of the piston resembles what would be considered an "HD" piston by most other piston manufacturers, as does the wristpin. Wossner pistons also come with a "soft" side skirt coating to ensure proper engine break-in. The 8.0:1 compression ratio provides a wide tuning window for daily driven applications, but can handle the abuse of extremely high boost levels on dedicated race vehicles with minimal change in spool characteristics. Wossner pistons should be high on the list of options for anyone looking to build their engine.
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 06-18-2009   #2
Re: Wossner Pistons Now Available @ MAPerformance! Introductory Sale Inside!
Oh i've heard of these. I think HKS sells Wossners under the HKS name though of course.
It was either them of JUN.
Either way, nice parts.
Old 06-18-2009   #3
Convince them to make some for a stroker setup!
Old 06-19-2009   #4
v8klla
v8klla's Avatar
I will do what I can sir! Apparently they make a 102mm stroker piston as there is some crankshaft with that stroke readily available overseas, doesn't do us much good though unless you want to buy a BC crankshaft lol.
P: 763-545-3800
