This whole thread was good for a laugh, but this is the best!!!
Originally Posted by Gravy
but he re-used the water that didn't burn and re-cycled it into the tank.
Our education system has gone down the shitter. Since when does water burn??
Here is an bit from his Ebay ad:
Also there is no secret calculations to get multiple units to work on your car. I will not help you , it will help you burn out your alternator is what it will do and any gains you would have seen will be eaten up in load on the alternators , now there is a way to get around it and this only works in electrolysis, you get the same output if you say use 22.5 watts or 225 watts . You can use a dc to dc converter and run the unit at 1.5 volts ( min is 1.2 volts ) and 15 amps or you can run it at 12 volts at 15 amps , the output will be the same. If you use a dc to dc converter to do the job , then you could in reality run more units. Most people barely have room for one and do not want to maintain more than one , it would be a hassle and hardly worth it as you would still not see much more in gains and still need to run on gasoline or diesel.
If you admit that the amount of gains will be eaten up by the alternator by hooking up multiple units, how would it be much different than running one unit?
Also, it holds one quart of water. How much hydrogen do you think you are going to get from one quart of water? This is another marketing gimmick praying on people that already pay too much for fuel. I know a guy that swore up and down his platinum injection doo hicky made his gas mileage much better. He bought those vials of "platinum" for quite a while until he realized that it wasn't actually doing anything. A lot of these things have a placebo effect. You think it is doing something, you pay attention more and you are a little easier on the gas pedal.
